I have a new Win 11 Surface pro 9. All the suggestions I have found on this subject do not work. You would think ST would address the problem if they want to sell chips. Microsoft is also at fault. They keep pushing Win11, but I have found so many incompatibilities. May have to revert everything to Win10. Progress is not always progress. I have been working Windows since before Windows(MS1). This is the worst upgrade I have ever seen.
I tested the CubeMX latest version 6.4.0 on Windows 11 and I didn't face any issue during the install nor during the launch. It works perfectly on my side.
The issue that you faced seems to come from Java, Anyways I am very glad that you found a way to make STM32CubeMX 6.4.0 work on your computer.
If you issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Regards,
Sara.
