STM32CubeMX 6.17. 0 not generating correct cmake file for STM32WL33
Hi ST,
This is just to let you know that STM32CubeMX version 6.17.0 does not generate correct cmake file for the STM32WL33 and this error results in the microntroller not starting up correctly but hangs in function
SystemInit() in system_stm32wl3x.c.
The problems is that the wrong is -mcpu is generated.
The problem can be found in the file -> path/to/dir/cmake/gcc-arm-none-eabi.cmake
# MCU specific flags
set(TARGET_FLAGS "-mcpu=cortex-m4 ") // wrong for the WL33
set(TARGET_FLAGS "-mcpu=cortex-m0plus ") // correct for the WL33
Ola
Hello @ola
Let me thank you for bringing this issue to our attention.
The issue has been escalated to dev team under internal ticket: CDM0062228
Thanks.
Mahmoud
Hello @@ola
Let me thank you for posting.
For more investigation, could you provide please your Ioc.File.
Thanks.
Mahmoud
olaAuthor
Hi Mahmoud,
The problem is not the ioc file. The problem is in the auto generation of the cmake file I mentioned in my message.
I have attached the ioc file as per your request.
Ola
Hello @ola
Thanks.
Mahmoud
