Caan
STM32CUBEMX 6.16.0/6.16.1 Not generating full code for Touchgfx
I am trying to build a project using STM32CUBEMX 6.16.0 and 6.16.1 but the ioc file doesn't export the full supporting header file for the touchgfx.
MHoll.2
MHoll.2Best answer
Senior III
You have to run (at least once) the code generation in TouchGFX 4.26.0 Designer (the Windows PC application is normaly where You have the STM32Cube repository:
C:\Users\<YourUsername>\STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-TOUCHGFX\4.26.0\Utilities\
Open the (generated) ApplicationTemplate.touchgfx.part file in TouchGFX designer and click the "Generate Code" Button.
MHoll.2
MHoll.2Best answer
Senior III
Caan
CaanAuthor
Thank You, Your solution worked.
