peterdonchev
Senior
STM32CubeMX 6.13.0 wrong code generated for handling EXTI on STM32H747 M4 Core
STM32CubeMX 6.13.0.
MCU - STM32H747.
LL library selected.
Generating the EXTI2_IRQHandler for the M4 core:
void EXTI2_IRQHandler(void)
 /* USER CODE BEGIN EXTI2_IRQn 0 */
 /* USER CODE END EXTI2_IRQn 0 */
 if (LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_2) != RESET)
 LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_2);
 /* USER CODE BEGIN LL_EXTI_LINE_2 */
 /* USER CODE END LL_EXTI_LINE_2 */
 /* USER CODE BEGIN EXTI2_IRQn 1 */
 /* USER CODE END EXTI2_IRQn 1 */
The generated code uses LL_EXTI_IsActiveFlag_0_31 and LL_C_EXTI_ClearFlag_0_31 instead of LL_C2_EXTI_IsActiveFlag_0_31 and LL_C2_EXTI_ClearFlag_0_31 for CORE2.
Ghofrane GSOURI
Hello @peterdonchev
First let me thank you for posting.
I'm currently checking this internally and will get back to you as soon as possible.
THX
Ghofrane
mƎALLEm
Hello @peterdonchev ,
Kindly use </> button to paste a code. See Tips here. I'm editing your post.
Ghofrane GSOURI
Hello @peterdonchev
Actually I tried to reproduce the issue mentioned above but I found that CubeMX 6.13.0 works just fine and this is my generated code :
I am sharing my IOC with you to double check my configuration.
I would appreciate it if you could provide your IOC to continue the investigation.
I will be waiting for your feedback.
THX
Ghofrane
peterdonchev
Senior
Hello @Ghofrane GSOURI ,
Can I share it with you privately?
Regards,
Peter
Ghofrane GSOURI
Hello @peterdonchev
Yes of course .
BR,
Ghofrane
Semer CHERNI
Hello @peterdonchev
The issue is fixed in the latest release of the STM32CubeMX (6.14.0).
KR,
Semer.
