Pawe? Jab?o?ski
Nov 24, 2018 7:16 PM UTC
STM32CubeMX 5.0 under Linux
I installed new STM32CubeMX 5.0.0 on my computer under Ubuntu 18.04. After start, program doesn't response. When I run it via terminal, I have some warns and error. Below I attached logs from terminal. After the last line of this log, I don't have even program GUI. Does anyone had problem like that?
Thanks in advice
Paweł
2018-11-24 19:33:27,745 [INFO] MicroXplorer:486 - Detected Java Version = 11.0.1
2018-11-24 19:33:27,751 [INFO] ApplicationProperties:181 - Using Application install path: /home/pawel/STM32CubeMX
2018-11-24 19:33:27,762 [INFO] DbMcusXml:68 - Set database path to: /home/pawel/STM32CubeMX//db//mcu/
2018-11-24 19:33:27,767 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/pawel/STM32CubeMX//db//plugins/boardmanager/
2018-11-24 19:33:27,768 [INFO] DbMcus:262 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:27,768 [INFO] DbBoards:224 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:27,770 [INFO] APIGFXSelector:72 - Set database path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-11-24 19:33:27,773 [INFO] DbMcusAds:72 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,774 [INFO] DbMcusDocs:90 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,776 [INFO] DbMcusJson:58 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,778 [INFO] DbBoardsDocs:82 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,779 [INFO] DbBoardsJson:51 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,798 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,016 [INFO] RulesReader:53 - Compatibility file has been processed (127 Rules)
2018-11-24 19:33:28,074 [INFO] STM32CubeMX:31 - Starting STM32CubeMX
2018-11-24 19:33:28,504 [INFO] MainPanel:139 - HeapMemory: 134217728
2018-11-24 19:33:28,673 [INFO] DbMcusXml:68 - Set database path to: /home/pawel/STM32CubeMX//db//mcu/
2018-11-24 19:33:28,673 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/pawel/STM32CubeMX//db//plugins/boardmanager/
2018-11-24 19:33:28,674 [INFO] DbMcus:262 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:28,674 [INFO] DbBoards:224 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:28,675 [INFO] APIGFXSelector:72 - Set database path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-11-24 19:33:28,675 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,676 [INFO] DbMcusAds:72 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,676 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,677 [INFO] DbMcusDocs:90 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,677 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,678 [INFO] DbMcusJson:58 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,678 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,678 [INFO] DbBoardsDocs:82 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,679 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,679 [INFO] DbBoardsJson:51 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,680 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,680 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,703 [INFO] ApplicationProperties:181 - Using Application install path: /home/pawel/STM32CubeMX
2018-11-24 19:33:28,706 [INFO] PluginManage:167 - Search for loadable plugins [exclusion list=]
2018-11-24 19:33:28,707 [INFO] PluginManage:289 - Check plugin projectmanager
2018-11-24 19:33:28,824 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2018-11-24 19:33:28,825 [INFO] PluginManage:289 - Check plugin filemanager
2018-11-24 19:33:28,885 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2018-11-24 19:33:28,885 [INFO] PluginManage:289 - Check plugin tools
2018-11-24 19:33:28,888 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2018-11-24 19:33:28,888 [INFO] PluginManage:289 - Check plugin ipmanager
2018-11-24 19:33:28,897 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2018-11-24 19:33:28,897 [INFO] PluginManage:289 - Check plugin clock
2018-11-24 19:33:28,906 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2018-11-24 19:33:28,907 [INFO] PluginManage:289 - Check plugin updater
2018-11-24 19:33:28,925 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2018-11-24 19:33:28,926 [INFO] PluginManage:289 - Check plugin pinoutandconfiguration
2018-11-24 19:33:28,933 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2018-11-24 19:33:28,933 [INFO] PluginManage:289 - Check plugin thirdparty
2018-11-24 19:33:28,946 [INFO] ThirdPartyDb:293 - Open Third Party DataBase File (/home/pawel/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml) : 0 ms. number of Sw pack : 0
2018-11-24 19:33:28,954 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2018-11-24 19:33:28,954 [INFO] PluginManage:289 - Check plugin power
2018-11-24 19:33:28,993 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2018-11-24 19:33:28,993 [INFO] PluginManage:289 - Check plugin pinoutconfig
2018-11-24 19:33:29,036 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2018-11-24 19:33:29,037 [INFO] PluginManage:289 - Check plugin analytics
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.thoughtworks.xstream.core.util.Fields (file:/home/pawel/STM32CubeMX/plugins/analytics.jar) to field java.util.TreeMap.comparator
WARNING: Please consider reporting this to the maintainers of com.thoughtworks.xstream.core.util.Fields
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
2018-11-24 19:33:29,284 [INFO] UserProfileFactory:23 - /com/st/library/analyticscore
2018-11-24 19:33:29,287 [INFO] UserProfileFactory:25 - 4c813135_154f_412c_8980_4024633db7d4
2018-11-24 19:33:29,297 [INFO] AnalyticsPlugin:146 - Accepted Software Licenses: Error : could not load the licence version !
2018-11-24 19:33:29,298 [INFO] AnalyticsPlugin:148 - Accepted CMSIS Pack Licenses:
2018-11-24 19:33:29,298 [INFO] AnalyticsPlugin:150 - Accepted Firmware Licenses:
2018-11-24 19:33:29,298 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2018-11-24 19:34:13,954 [ERROR] IntegrityCheckThread:90 - Cannot obtain updater plugin
2018-11-24 19:34:13,955 [INFO] IntegrityCheckThread:94 - End integrity checks thread
2018-11-24 19:34:13,955 [INFO] ThirdPartyDb:263 - Close Third Party DataBase File (/home/pawel/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml)
seyyah
Jan 3, 2019 11:23 AM UTC
Hi @Vitaliy Shurpa​,
Your trick produces "system tray not supported" error.
root@me# java -jar updater.jar
SPicc
Jan 12, 2019 11:41 AM UTC
Same problem with Archlinux and 5.0.1 version
Marie-Christine CAYALE
Jan 14, 2019 12:34 PM UTC
​from my side I observed issue with VMWare and Ubuntu 16.04.5 and CubeMx5.0.1
it could be solved by doing :
sudo apt-get install default-jre
mail239955_stm1_stmicro_com
Jan 14, 2019 1:37 PM UTC
I hoped installing that package was going to do some magic with the install script that wasn't done by picking up a jre... but it didn't.
It seems not related to a particular jre. People have already tested ojdk 8-9-10-11 with alternate success.
I've tested all the proposed solution here on Debian sid and I'm still experiencing the problem.
https://www.borgonovo.net
Jan 15, 2019 11:07 AM UTC
also following package may be needed
sudo apt-get install lib32ncurses5
Vitaliy Shurpa
Jan 16, 2019 6:20 PM UTC
Ubuntu 18.10
It didn't help.
Sergiy1
Jan 18, 2019 9:45 PM UTC
I had the same problem on the Archlinux with jdk 11.
But it's not related to the java version or linux.
It's a bug in the tool - the "PluginManage" class.
As far as I can tell by decompiling the java code, the plugins are originally placed in a list in the order they appear in the log. And then there will be multiple loops where if given plugin's position in the loop doesn't match plugin's tabindex, it'll try to remove the plugin from the list and then insert it at the tabindex (while sort of trying to ignore plugins with "-1" tabindex).
In my particular case, grepping the log for "Loaded plugin" looked like this:
2019-01-18 08:02:57,343 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2019-01-18 08:02:57,349 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2019-01-18 08:02:57,508 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2019-01-18 08:02:57,562 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2019-01-18 08:02:57,564 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2019-01-18 08:02:57,578 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2019-01-18 08:02:57,584 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2019-01-18 08:02:57,590 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2019-01-18 08:02:57,613 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2019-01-18 08:02:57,625 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2019-01-18 08:02:57,659 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
And the culprit were "tools, tabindex: 5" and "ipmanager, tabindex:5" - the loop would have one of them at index 4 and the other at index 5. So it'll try removing one from index 4 (and as a side effect moving the other from index 5 to index 4) and placing removed one to 5. Repeat forever. (It's actually more complicated: "-1" tab index plugins are part of the story as is the fact that plugins with tabindex 1 and 3 are loaded after tools and ipmanager, but I can't easily explain the broken logic in plain english).
I changed tabindex from 5 to 4 in "com/st/microxplorer/plugins/tools/Plugin.properties" file from "/opt/stm32cubemx/plugins/tools.jar" (which is just a zip archive) and it now starts fine.
To sum up, the workaround is something like: go through the log and find the first two plugins with the same non-negative tabindex, then change the tabindex (by modifying plugin's jar file) for one of them.
S H
Jan 19, 2019 10:21 PM UTC
This workaround works for me. I had to change the tabindex from 5 to 6 because 4 was already used by another part.
AJuto
Jan 22, 2019 11:48 AM UTC
This solution, with tabindex=6, works also for me.
Many thanks.
PPako
Jan 22, 2019 9:55 PM UTC
Have to admit that solution from Sergiy works perfectly but guys, someone responsible for CubeMX read this ? Take a look, this problem isnt reported properly or someone forgot about this part of comunity.
BNezh
Jan 25, 2019 9:48 PM UTC
Same here, Arch 4.20.3, openjdk 10.0.2
Myzhar
Jan 31, 2019 10:17 AM UTC
The @Sergiy​ solution worked for me too, changing the index to 6 instead that 4 as he suggested
