Pawe? Jab?o?ski
Nov 24, 2018 7:16 PM UTC
STM32CubeMX 5.0 under Linux
I installed new STM32CubeMX 5.0.0 on my computer under Ubuntu 18.04. After start, program doesn't response. When I run it via terminal, I have some warns and error. Below I attached logs from terminal. After the last line of this log, I don't have even program GUI. Does anyone had problem like that?
Thanks in advice
Paweł
2018-11-24 19:33:27,745 [INFO] MicroXplorer:486 - Detected Java Version = 11.0.1
2018-11-24 19:33:27,751 [INFO] ApplicationProperties:181 - Using Application install path: /home/pawel/STM32CubeMX
2018-11-24 19:33:27,762 [INFO] DbMcusXml:68 - Set database path to: /home/pawel/STM32CubeMX//db//mcu/
2018-11-24 19:33:27,767 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/pawel/STM32CubeMX//db//plugins/boardmanager/
2018-11-24 19:33:27,768 [INFO] DbMcus:262 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:27,768 [INFO] DbBoards:224 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:27,770 [INFO] APIGFXSelector:72 - Set database path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-11-24 19:33:27,773 [INFO] DbMcusAds:72 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,774 [INFO] DbMcusDocs:90 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,776 [INFO] DbMcusJson:58 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,778 [INFO] DbBoardsDocs:82 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,779 [INFO] DbBoardsJson:51 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:27,798 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,016 [INFO] RulesReader:53 - Compatibility file has been processed (127 Rules)
2018-11-24 19:33:28,074 [INFO] STM32CubeMX:31 - Starting STM32CubeMX
2018-11-24 19:33:28,504 [INFO] MainPanel:139 - HeapMemory: 134217728
2018-11-24 19:33:28,673 [INFO] DbMcusXml:68 - Set database path to: /home/pawel/STM32CubeMX//db//mcu/
2018-11-24 19:33:28,673 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/pawel/STM32CubeMX//db//plugins/boardmanager/
2018-11-24 19:33:28,674 [INFO] DbMcus:262 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:28,674 [INFO] DbBoards:224 - Set plugin images path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/images/
2018-11-24 19:33:28,675 [INFO] APIGFXSelector:72 - Set database path to: /home/pawel/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-11-24 19:33:28,675 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,676 [INFO] DbMcusAds:72 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,676 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,677 [INFO] DbMcusDocs:90 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,677 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,678 [INFO] DbMcusJson:58 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,678 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,678 [INFO] DbBoardsDocs:82 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,679 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,679 [INFO] DbBoardsJson:51 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,680 [WARN] DbFile:31 - Overriding database path with different value: /home/pawel/.stmcufinder/plugins/mcufinder/ => /home/pawel/.stmcufinder/plugins/mcufinder
2018-11-24 19:33:28,680 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/pawel/.stmcufinder/plugins/mcufinder//mcu/
2018-11-24 19:33:28,703 [INFO] ApplicationProperties:181 - Using Application install path: /home/pawel/STM32CubeMX
2018-11-24 19:33:28,706 [INFO] PluginManage:167 - Search for loadable plugins [exclusion list=]
2018-11-24 19:33:28,707 [INFO] PluginManage:289 - Check plugin projectmanager
2018-11-24 19:33:28,824 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2018-11-24 19:33:28,825 [INFO] PluginManage:289 - Check plugin filemanager
2018-11-24 19:33:28,885 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2018-11-24 19:33:28,885 [INFO] PluginManage:289 - Check plugin tools
2018-11-24 19:33:28,888 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2018-11-24 19:33:28,888 [INFO] PluginManage:289 - Check plugin ipmanager
2018-11-24 19:33:28,897 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2018-11-24 19:33:28,897 [INFO] PluginManage:289 - Check plugin clock
2018-11-24 19:33:28,906 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2018-11-24 19:33:28,907 [INFO] PluginManage:289 - Check plugin updater
2018-11-24 19:33:28,925 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2018-11-24 19:33:28,926 [INFO] PluginManage:289 - Check plugin pinoutandconfiguration
2018-11-24 19:33:28,933 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2018-11-24 19:33:28,933 [INFO] PluginManage:289 - Check plugin thirdparty
2018-11-24 19:33:28,946 [INFO] ThirdPartyDb:293 - Open Third Party DataBase File (/home/pawel/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml) : 0 ms. number of Sw pack : 0
2018-11-24 19:33:28,954 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2018-11-24 19:33:28,954 [INFO] PluginManage:289 - Check plugin power
2018-11-24 19:33:28,993 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2018-11-24 19:33:28,993 [INFO] PluginManage:289 - Check plugin pinoutconfig
2018-11-24 19:33:29,036 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2018-11-24 19:33:29,037 [INFO] PluginManage:289 - Check plugin analytics
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.thoughtworks.xstream.core.util.Fields (file:/home/pawel/STM32CubeMX/plugins/analytics.jar) to field java.util.TreeMap.comparator
WARNING: Please consider reporting this to the maintainers of com.thoughtworks.xstream.core.util.Fields
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
2018-11-24 19:33:29,284 [INFO] UserProfileFactory:23 - /com/st/library/analyticscore
2018-11-24 19:33:29,287 [INFO] UserProfileFactory:25 - 4c813135_154f_412c_8980_4024633db7d4
2018-11-24 19:33:29,297 [INFO] AnalyticsPlugin:146 - Accepted Software Licenses: Error : could not load the licence version !
2018-11-24 19:33:29,298 [INFO] AnalyticsPlugin:148 - Accepted CMSIS Pack Licenses:
2018-11-24 19:33:29,298 [INFO] AnalyticsPlugin:150 - Accepted Firmware Licenses:
2018-11-24 19:33:29,298 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2018-11-24 19:34:13,954 [ERROR] IntegrityCheckThread:90 - Cannot obtain updater plugin
2018-11-24 19:34:13,955 [INFO] IntegrityCheckThread:94 - End integrity checks thread
2018-11-24 19:34:13,955 [INFO] ThirdPartyDb:263 - Close Third Party DataBase File (/home/pawel/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml)
taraben
Nov 25, 2018 5:02 PM UTC
I have the same problem here.
Ubuntu 18.10.
I add that a java thread takes 100% of one CPU core. But there is no GUI output at all.
Just high CPU load.
Regards, Adib.
Andreas Bolsch
Lead III
Nov 25, 2018 7:46 PM UTC
Probably that's the problem: [INFO] MicroXplorer:486 - Detected Java Version = 11.0.1
Works just fine on my system: [INFO] MicroXplorer:486 - Detected Java Version = 1.8.0_181
Try to stick to an older java version ...
taraben
Nov 25, 2018 9:14 PM UTC
Still Buggy.
I removed the OpenJRE 11 and installed OpenJRE 8 instead.
it detects a java 1.8 now.
same error: the program hangs after the updater plugin ERROR.
Adib.
jbren
Nov 30, 2018 7:16 AM UTC
I have exactly the same problem
[INFO] MicroXplorer:486 - Detected Java Version = 1.8.0_191
and same error: the program hangs after the updater plugin ERROR with 100% use of one CPU.
Andreas Bolsch
Lead III
Nov 30, 2018 8:15 AM UTC
That's really weird, I would do a
strace -f -e trace=open,stat <cubemx_cmd>
this might give a hint about missing files, file permissions. Any security policy enabled (SELinux or Apparmor)?
skufaev
Dec 1, 2018 3:43 PM UTC
Same here. Starting fail after MX update.
Deleted all, fresh install for 5.0.0.
Run again and failed again. Same error.
Ubuntu 18.10
2018-12-01 18:34:05,344 [INFO] MicroXplorer:486 - Detected Java Version = 10.0.2
2018-12-01 18:34:05,350 [INFO] ApplicationProperties:181 - Using Application install path: /home/dev/STM32CubeMX
2018-12-01 18:34:05,359 [INFO] DbMcusXml:68 - Set database path to: /home/dev/STM32CubeMX//db//mcu/
2018-12-01 18:34:05,363 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/dev/STM32CubeMX//db//plugins/boardmanager/
2018-12-01 18:34:05,363 [INFO] DbMcus:262 - Set plugin images path to: /home/dev/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-01 18:34:05,363 [INFO] DbBoards:224 - Set plugin images path to: /home/dev/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-01 18:34:05,365 [INFO] APIGFXSelector:72 - Set database path to: /home/dev/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-12-01 18:34:05,423 [WARN] ApiFinderProperties:107 - /home/dev/.stmcufinder/plugins/mcufinder/mcu/mcuFinder.mfd doesn't exist
2018-12-01 18:34:05,425 [INFO] DbMcusAds:72 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:05,426 [INFO] DbMcusDocs:90 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:05,427 [INFO] DbMcusJson:58 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:05,428 [INFO] DbBoardsDocs:82 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:05,429 [INFO] DbBoardsJson:51 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:05,666 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:05,802 [INFO] RulesReader:53 - Compatibility file has been processed (127 Rules)
2018-12-01 18:34:05,843 [INFO] STM32CubeMX:31 - Starting STM32CubeMX
2018-12-01 18:34:06,202 [INFO] MainPanel:139 - HeapMemory: 264241152
2018-12-01 18:34:06,324 [INFO] DbMcusXml:68 - Set database path to: /home/dev/STM32CubeMX//db//mcu/
2018-12-01 18:34:06,325 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/dev/STM32CubeMX//db//plugins/boardmanager/
2018-12-01 18:34:06,325 [INFO] DbMcus:262 - Set plugin images path to: /home/dev/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-01 18:34:06,326 [INFO] DbBoards:224 - Set plugin images path to: /home/dev/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-01 18:34:06,326 [INFO] APIGFXSelector:72 - Set database path to: /home/dev/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-12-01 18:34:06,327 [WARN] DbFile:31 - Overriding database path with different value: /home/dev/.stmcufinder/plugins/mcufinder/ => /home/dev/.stmcufinder/plugins/mcufinder
2018-12-01 18:34:06,327 [INFO] DbMcusAds:72 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:06,327 [INFO] DbMcusDocs:90 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:06,328 [WARN] DbFile:31 - Overriding database path with different value: /home/dev/.stmcufinder/plugins/mcufinder/ => /home/dev/.stmcufinder/plugins/mcufinder
2018-12-01 18:34:06,328 [INFO] DbMcusJson:58 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:06,329 [WARN] DbFile:31 - Overriding database path with different value: /home/dev/.stmcufinder/plugins/mcufinder/ => /home/dev/.stmcufinder/plugins/mcufinder
2018-12-01 18:34:06,329 [INFO] DbBoardsDocs:82 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:06,330 [WARN] DbFile:31 - Overriding database path with different value: /home/dev/.stmcufinder/plugins/mcufinder/ => /home/dev/.stmcufinder/plugins/mcufinder
2018-12-01 18:34:06,330 [INFO] DbBoardsJson:51 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:06,331 [WARN] DbFile:31 - Overriding database path with different value: /home/dev/.stmcufinder/plugins/mcufinder/ => /home/dev/.stmcufinder/plugins/mcufinder
2018-12-01 18:34:06,331 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/dev/.stmcufinder/plugins/mcufinder//mcu/
2018-12-01 18:34:06,348 [INFO] ApplicationProperties:181 - Using Application install path: /home/dev/STM32CubeMX
2018-12-01 18:34:06,350 [INFO] PluginManage:167 - Search for loadable plugins [exclusion list=]
2018-12-01 18:34:06,351 [INFO] PluginManage:289 - Check plugin thirdparty
2018-12-01 18:34:06,367 [INFO] ThirdPartyDb:293 - Open Third Party DataBase File (/home/dev/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml) : 1 ms. number of Sw pack : 0
2018-12-01 18:34:06,374 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2018-12-01 18:34:06,374 [INFO] PluginManage:289 - Check plugin tools
2018-12-01 18:34:06,376 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2018-12-01 18:34:06,376 [INFO] PluginManage:289 - Check plugin analytics
2018-12-01 18:34:06,522 [INFO] UserProfileFactory:23 - /com/st/library/analyticscore
2018-12-01 18:34:06,528 [INFO] UserProfileFactory:25 - 667f5ad0_5fa4_4bb0_b401_0d59e5173e3f
2018-12-01 18:34:06,535 [INFO] AnalyticsPlugin:146 - Accepted Software Licenses: Error : could not load the licence version !
2018-12-01 18:34:06,535 [INFO] AnalyticsPlugin:148 - Accepted CMSIS Pack Licenses:
2018-12-01 18:34:06,535 [INFO] AnalyticsPlugin:150 - Accepted Firmware Licenses:
2018-12-01 18:34:06,535 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2018-12-01 18:34:06,535 [INFO] PluginManage:289 - Check plugin filemanager
2018-12-01 18:34:06,599 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2018-12-01 18:34:06,599 [INFO] PluginManage:289 - Check plugin ipmanager
2018-12-01 18:34:06,605 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2018-12-01 18:34:06,605 [INFO] PluginManage:289 - Check plugin power
2018-12-01 18:34:06,624 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2018-12-01 18:34:06,625 [INFO] PluginManage:289 - Check plugin pinoutandconfiguration
2018-12-01 18:34:06,631 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2018-12-01 18:34:06,631 [INFO] PluginManage:289 - Check plugin projectmanager
2018-12-01 18:34:06,660 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2018-12-01 18:34:06,660 [INFO] PluginManage:289 - Check plugin clock
2018-12-01 18:34:06,665 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2018-12-01 18:34:06,666 [INFO] PluginManage:289 - Check plugin updater
2018-12-01 18:34:06,678 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2018-12-01 18:34:06,679 [INFO] PluginManage:289 - Check plugin pinoutconfig
2018-12-01 18:34:06,692 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2018-12-01 18:34:51,374 [ERROR] IntegrityCheckThread:90 - Cannot obtain updater plugin
2018-12-01 18:34:51,375 [INFO] IntegrityCheckThread:94 - End integrity checks thread
2018-12-01 18:34:51,375 [INFO] ThirdPartyDb:263 - Close Third Party DataBase File (/home/dev/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml)
FGmei
Dec 2, 2018 5:49 AM UTC
I'm having the same issue, strange launch read-out in terminal, and CPU hogging.
Anyone have an ST link to an older version?
mail239955_stm1_stmicro_com
Dec 3, 2018 9:11 PM UTC
Same here. Debian sid.
Was ST notified of the problem?
https://www.borgonovo.net
olivier
Dec 4, 2018 1:59 PM UTC
Same here, too. Ubuntu 18.10 with and Java 1.8.0_191.
paulg
Dec 4, 2018 2:26 PM UTC
Same here. Running on Linux Mint 17 and java version "1.8.0_191".
