SShar.16
Aug 25, 2022 7:14 AM UTC
STM32CubeIDE not creating middleware USB_Device.
I am not able to configure USB_Device mode (USB_Device not enabling permanently disabled how to enable USB_Device in middleware).
I want to select CDC in USB_Device.
please give me solution for the same ASAP.
Ghofrane GSOURI
Aug 25, 2022 8:22 AM UTC
Good morning @SShar.16​
I used stm32cubeMX 6.6.1 and stm32cubeIDE 1.10.1 and Nucleo-F767ZI in order to show you how to configure USB _Device mode
  • First go to System Core ==> select RCC ==> click on High speed Clock and choose "BYPASS clock source "
  • Second go to "clock configuration " make sure that the input frequency is 8 MHZ
  • Third go to "connectivity" and select USB_OTG_FS click on Mode and select "device only"
  • Then go to "middleware " click on "USB _DEVICE" click on Class FO FS IP and choose Communication Device Class
  • finally go to "project manager " and increase the Heap size to 0x600 and generate your code
0693W00000StjrMQAR.png you will find bellow the cubeMX file please have a look
Ghofrane
