Khouloud ZEMMELI
Mar 9, 2021 9:38 AM UTC
Hello @KBass.1​
Thanks for your feedback, could you please share your ioc file to check the config and the part number used?
Khouloud
KBass.1
KBass.1Author
Mar 9, 2021 9:40 PM UTC
I can't access the .ioc file right now, but I'm using a NUCLEO-H743ZI2​ and the issue happens when setting I2S3 to Full-Duplex Slave mode.
Khouloud ZEMMELI
Mar 10, 2021 3:11 PM UTC
Hi @KBass.1​
Thank you for specifying the part number used which helped me to reproduce the issue, it's linked to some PN and not to all H7 serie.
In fact, this problem is due to the presence of the Transmission mode parameter in the configuration part, so that the mode value will be taken directly from there.
Issue will be fixed, thanks again for raising such a problem to our attention and for your contribution.
Khouloud
