JLoh
STM32CubeIDE 1.15 Bug (switching from SysTick to TIM16)
I'm using the Nucleo-C031C6 board, and I chose this (NUCLEO-C031C6) from the board selector when starting the IDE. (STM32CubeIDE v1.15).
I tried switching Timebase Source (in SYS menu) from SysTick to TIM16, then when I compiled, I got this error:
../Core/Inc/stm32c0xx_hal_conf.h:237:11: fatal error: stm32c0xx_hal_tim.h: No such file or directory
It is just a bare project with no user code added.
I had to switch from SysTick to TIM16 because I was trying out ThreadX.
STTwo-32
STTwo-32Best answer
Hello @JLoh
You have to check your Paths and include the path of this HAL Driver.
For this issue, I've been able to reproduce it and I will escalate it internally for correction (in internal ticket number 177285).
Thank you for reporting  This.
Best Regards
STTwo-32
JLoh
JLohAuthor
It seemed to me that the necessary files weren't copied. To workaround this, I just enabled another Timer (TIM16) and this bug disappeared.
STTwo-32
STTwo-32Best answer
Hello @JLoh
Best Regards
STTwo-32
Explorer
April 21, 2024
Hello.
Do you have any news about internal ticket 177285 to this bug?
I want to try Threadx with this MCU.
Thank you very much.
