STM32 CubeMx Exception
I am running into thread exception while running CubeMx on MacOs M4 Pro.
Platform: MacOs M4 Pro
CubeMx (About):  Java (21.0.8 (9))  [STM32CubeMX 6.16.0 Mac ARM]
When I try to open Airoc-Wi-Fi-Bluetooth Pack under Middleware, I get following exception and call stack.
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: column must be valid, was-1
	at org.jdesktop.swingx.JXTreeTable.isHierarchical(JXTreeTable.java:2022)
	at org.jdesktop.swingx.JXTreeTable.getEditingRow(JXTreeTable.java:1162)
	at java.desktop/javax.swing.JTable$AccessibleJTable.getAccessibleChild(JTable.java:7222)
	at java.desktop/javax.swing.JTable$AccessibleJTable.getAccessibleAt(JTable.java:7612)
	at java.desktop/javax.swing.JTable$AccessibleJTable.valueChanged(JTable.java:7133)
	at java.desktop/javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:231)
	at java.desktop/javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:206)
	at java.desktop/javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:258)
	at java.desktop/javax.swing.DefaultListSelectionModel.setAnchorSelectionIndex(DefaultListSelectionModel.java:824)
	at java.desktop/javax.swing.JTable.clearSelectionAndLeadAnchor(JTable.java:2197)
	at java.desktop/javax.swing.JTable.tableChanged(JTable.java:4438)
	at org.jdesktop.swingx.JXTable.tableChanged(JXTable.java:1529)
	at org.jdesktop.swingx.JXTreeTable.tableChanged(JXTreeTable.java:1250)
	at java.desktop/javax.swing.table.AbstractTableModel.fireTableChanged(AbstractTableModel.java:302)
	at java.desktop/javax.swing.table.AbstractTableModel.fireTableStructureChanged(AbstractTableModel.java:222)
	at org.jdesktop.swingx.JXTreeTable$TreeTableModelAdapter$2.propertyChange(JXTreeTable.java:2261)
	at java.desktop/java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:343)
	at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:336)
	at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:268)
	at java.desktop/java.awt.Component.firePropertyChange(Component.java:8717)
	at java.desktop/javax.swing.JTree.setModel(JTree.java:946)
	at org.jdesktop.swingx.JXTree.setModel(JXTree.java:1501)
	at org.jdesktop.swingx.JXTreeTable.setTreeTableModel(JXTreeTable.java:1184)
	at com.st.microxplorer.plugins.thirdparty.gui.view.treetable.ComponentTreeTable.updateModel(ComponentTreeTable.java:172)
	at com.st.microxplorer.plugins.thirdparty.gui.view.ComponentTreePanel.updateModelAndTable(ComponentTreePanel.java:244)
	at com.st.microxplorer.plugins.thirdparty.gui.view.ComponentTreePanel.update(ComponentTreePanel.java:146)
	at com.st.microxplorer.plugins.thirdparty.gui.view.ThirdPartyUI.updateAllPanels(ThirdPartyUI.java:425)
	at com.st.microxplorer.plugins.thirdparty.gui.view.ThirdPartyWindow.show(ThirdPartyWindow.java:130)
	at com.st.microxplorer.plugins.thirdparty.ThirdParty.showDialog(ThirdParty.java:959)
	at com.st.microxplorer.plugins.thirdparty.ThirdParty.openThirdParty(ThirdParty.java:1066)
	at com.st.microxplorer.plugins.thirdparty.ThirdParty.getSpecificTask(ThirdParty.java:572)
	at com.st.microxplorer.plugins.pinoutconfig.guiV5.PeripheralsListListener.mouseClicked(PeripheralsListListener.java:105)
	at java.desktop/java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:278)
	at java.desktop/java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:277)
	at java.desktop/java.awt.Component.processMouseEvent(Component.java:6624)
	at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3398)
	at java.desktop/java.awt.Component.processEvent(Component.java:6386)
	at java.desktop/java.awt.Container.processEvent(Container.java:2266)
	at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:4996)
	at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2324)
	at java.desktop/java.awt.Component.dispatchEvent(Component.java:4828)
	at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4948)
	at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4584)
	at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4516)
	at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2310)
	at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2780)
	at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:775)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714)
	at java.base/java.security.AccessController.doPrivileged(AccessController.java:400)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:98)
	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:747)
	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
	at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:744)
	at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
 Scrrenshot of what I am clicking on :
Is this normal ?
Hello @JenishR
Let me thank you for posting.
For more investigation, could you please provide your Ioc File.
Thanks.
Mahmoud
JenishRAuthor
Please check the video below to see the issue in Practice...
https://youtu.be/4XAnbo0Q9g0
Hello @JenishR ,
Further to your comment, I tested the same behavior on MAC OS Sequoia 15 M1 and the issue described was not reproduced by my side.
For more investigation, could you please provide the STM32CubeMX Log.File.
I will be waiting for your feedback.
Thanks.
Mahmoud
