MSale.1
Senior
Jul 28, 2021 9:52 PM UTC
STM32 CUBE IDE Bug This function (PeriphCommonClock_Config(); ) is not generated from the cube ide . is this normal in the new update or its a bug?
I use STM32H Series. H735 and H7A3
Imen.DBest answer
Jul 29, 2021 2:16 PM UTC
Hello @Community member​ ,
Please have a look at this post, and check if you have the same conditions as described by khouloud.
Otherwise, please provide more details on your use case to understand the issue.
Imen
Imen.DBest answer
Imen
Aug 5, 2021 10:48 AM UTC
​Hi @Community member​ ,
Please let me know if your issue is solved, if so please close this thread by marking "Select as Best" button.
Imen
