Nov 11, 2024 9:39 AM UTC
Start a new project with STM32H743VIT6
Dear all!
this is the first time i handle with STM32H7 series. in my project control ILI9488 by TouchGFX platform, 4 mosfets, 1 Led. in the first step, i try to blink a led at pin PB5 but seem unsuccess. i don't know how to fix, so can you share me my mistake and how to fix it. in attach file have schematic. can you take a look and share me your input.
mƎALLEm
mƎALLEmBest answer
Nov 21, 2024 11:10 AM UTC
Getting back to you regarding CubeMx. There is an issue in CubeMx V6.12.1.
For System clock @240MHz/VOS2, the HPRE prescaler needs to be  2.
So in your ioc file set HPRE to 2 instead of 1.
The issue seems to be fixed in an internal version that will be available soon on st.com.
If this solved your issue/answered your question, please accept it as solution.
Thank you.
mƎALLEm
Nov 11, 2024 9:56 AM UTC
If you comment the line MX_TouchGFX_Process(); what happens?
Nov 11, 2024 2:14 PM UTC
Dear!
i try to blink led at Pin B5, but can not. i update newest program. pls help me.
mƎALLEm
Nov 11, 2024 2:19 PM UTC
Sorry I don't see any change in the While loop:
 while (1)
 /* USER CODE END WHILE */
 /* USER CODE BEGIN 3 */
		HAL_GPIO_TogglePin(GPIOB, Run_led_Pin);
		HAL_Delay(300);
Could you please remove the call of MX_TouchGFX_Process() and try?
Nov 11, 2024 2:22 PM UTC
Dear!
this function was generate automatic when we use touchGFX designer, if we remove it. we can not display TFT LCD
mƎALLEm
mƎALLEmBest answer
Thank you.
