AThom.2
[SOLVED] STM32G030 CubeMX generated code won't compile - RTOS include not found
I have just created a new project with the latest version of CubeMX for an STM32G030F6Px and am using the code generator to provide basic bring-up code. However the generated project does not compile.
I am using System Workbench (version 1.17.0.201812190825; all updates applied), with the SW4STM32 option set in the Project Manager. However I receive the message:
../Drivers/CMSIS/RTOS2/Template/cmsis_os.h:157:10: fatal error: cmsis_os2.h: No such file or directory
I have not enabled FREERTOS in the project settings, so I'm not sure why this is being compiled. Any ideas?!
TDKBest answer
March 25, 2020
I'd recommend switching to STM32CubeIDE which, despite being newer, seems a bit better supported IMO.
You could grab the file yourself and move it. Seems like the path to it is slightly different than what your error message suggests.
https://github.com/STMicroelectronics/STM32CubeG0/tree/master/Drivers/CMSIS/RTOS2/Include
TDKBest answer
March 25, 2020
AThom.2
AThom.2Author
Many thanks for the response - I've tried with STM32CubeIDE but with exactly the same error unfortunately.
I've tried copying the missing file, but this just leads to a chain of similar missing files (at least 8!). I've found each one and copying it to the place it was looking for it and the latest error is now:
Drivers/CMSIS/Core/Template/ARMv8-M/main_s.o:C:/Users/Angus/Dropbox/STM32 Projects/PowerFlower/Debug/../Drivers/CMSIS/Core/Template/ARMv8-M/main_s.c:40: first defined here
There is another main() defined here (with a description of 'Secure main()') but I've no idea why!
AThom.2
AThom.2Author
TDK - thanks again for your answer. I realised I was running an old version of STM32CubeIDE (1.0) - I've updated to 1.3 and all works fine now.
Thanks again!
