Zakba.1
Apr 18, 2023 12:31 PM UTC
setting clock in stm32f7
Hi... for some reasons I cant regenerate my code from CubeMx but I need to change crystal 8M to oscillator 14.7456... in spite of replacing the clock function (void SystemClock_Config(void) ) with new one, my project does not work. what other changes do I need to consider for changing the clock in a project generated by CubeMx?
thank you in advance
FBLBest answer
Apr 19, 2023 3:29 PM UTC
Hello @Zakba.1​
If your project contains any code that is sensitive to timing (e.g delay loops...), you may need to update this code and consider the new oscillator frequency.
KnarfB
Apr 18, 2023 2:25 PM UTC
Well, why not generating 2 new dummy projects with the old and new settings and comparing the output. The new freq. may be to high for the old (PLL?) settings, and oscillator != crystal ?
hth
KnarfB
Zakba.1
Zakba.1Author
Apr 18, 2023 11:44 PM UTC
Well I tried that creating a dummy project with new clock configuration and replaced the generated system clock function with new one... this function as far as I know configures freq, pll, crystal or oscillator type in itself... except this function do I need to change any other configs in project?
Ps: I generated the code in cube with HAL lib
Post edited to adhere community guidelines.
FBLBest answer
Hello @Zakba.1​
