Real audio frequency and error between selected in SAI for the STM32N6 showing 0
I'm trying to configure my SAI to receive TDM packets from my external ADC. For some reason, no matter what sample rate I choose, the real audio and error between selected is always 0. I've tried changing the clocks to the SAI1 module to 50 and 100 MHz, but it didn't change anything.
Is this a visual bug with CubeMX or is it something with how I'm configuring the peripheral?
Thanks.
Souhaib MAZHOUDBest answer
Hello @csaji
Thank you for posting!
Actually, this is a known issue in CubeMX tracked by Internal ticket number: CDM0059442 (This is an internal tracking number and is not accessible or usable by customers.), And our development team is actively working on a resolution. I will keep you informed as soon as I have any updates.
BR, Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Hello @csaji
BR, Souhaib
csajiAuthor
Is there any update on this?
hi,i have seen the same error,can you tell me how to fix this bug?
