AFaya.1
May 4, 2022 7:09 AM UTC
Purpose of FSMC_NL pin and How to enable
HI,
I am working on STM32F413zh and i am trying to enable FSMC_NL gpio pin. I dont't know what is the purpose and how to enable this pin in STM32cubeMX. Please give me the support.
Thankyou.
AFaya.1
AFaya.1Best answer
May 13, 2022 4:57 AM UTC
I found it, thankyou for your reply. FSMC_NL for ALE purpose. While i was changed the configurations as per reference manual that was able to enable. Also working fine.
waclawek.jan
May 4, 2022 8:54 AM UTC
Why do you want to enable it if you don't know what is it's purpose?
It is used only for memories with multiplexed address/data buses, or in (quite rare) memories which require a latch signal for address.
What memory do you intend to connect to FSMC?
AFaya.1
AFaya.1AuthorBest answer
