RDodd.1
Sep 21, 2022 6:32 PM UTC
Please install Java JDK 11.0.10 or a more recent version on Mac M2
Hi ,
I am trying to install CubeMX on MAC M1 . I have been getting this error
Exe path is: /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs
Search java from relative path ----
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/./jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../../jre/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/./jre/Contents/Home/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../jre/Contents/Home/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../jre/Contents/Home/bin/java
Checking java in /Applications/SetupSTM32CubeMX-6.6.1.app/Contents/MacOs/../../../jre/Contents/Home/bin/java
My java echo is printing out this
echo $JAVA_HOME
/Library/Java/JavaVirtualMachines/jdk-19.jdk/Contents/Home
Can anyone pls help me with this
RDodd.1
RDodd.1Best answer
Oct 6, 2022 12:22 AM UTC
I got it resolved. It was just the java package which was missing . Thanks Imen
Sep 27, 2022 12:46 PM UTC
Hello @RDodd.1​ ,
Are you installing CubeMX with admin rights?
Make sure you have administrator rights and I advise you to follow the steps described in the UM1781, in the "3 Installing and running STM32CubeMX" section.
Please keep me informed about your progress on this issue.
Imen
RDodd.1
RDodd.1AuthorBest answer
