HMina.1
Jan 14, 2022 7:28 PM UTC
PLC01A1 Example Code for Nucelo-F401RE
Hello ST community, I recently bought a PLC01A1 expansion PLC board for my NUCLEO-F401RE and I am having trouble compiling the example code provided on the PLC01A1 website. After carefully integrating the code in STM32CubeIDE, I was prompted with the following error message "TIM6_DAC_IRQn' undeclared (first use in this function); did you mean 'TIM1_CC_IRQn". I checked the CubeMX (.ioc) file and TIM6 doesn't exist there. How can I run the example, and properly declare TIM6?
I very much appreciate the community help in advance, looking forward to hear a response from you.
Sara BEN HADJ YAHYA
Jan 26, 2022 2:31 PM UTC
Hello @HMina.1​ ,
Could you please share your ioc file and specify the CubeMX version?
Thanks,
Sara.
HMina.1
HMina.1Author
Feb 17, 2022 2:05 AM UTC
I apologize for the late response, I am using STM32CubeIDE Ver 1.7.0, per your request I attached the .ioc file to this answer.
Thanks for the help!
Sara BEN HADJ YAHYA
Feb 17, 2022 2:24 PM UTC
Hello @HMina.1​ ,
Could you please specify which example are you using and from where exactly did you download it?
Thanks,
Sara.
HMina.1
HMina.1Author
Feb 17, 2022 11:16 PM UTC
