Dec 4, 2023 6:42 AM UTC
Pdm2pcm
Hi tech team,
I am in search of pdm2pcm lib as per an5027.in cubemx it is grey_out. Unable to install.how to install ?
STTwo-32
STTwo-32Best answer
Dec 4, 2023 7:04 AM UTC
Hello @Alex_reynold
You should activate the CRC to be able to use the PDM2PCM.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Alex_reynold
Best Regards.
STTwo-32
