OctoSPI delay block code unnecessarily generated
Hi Everyone,
I noticed that CubeMX (version 6.14.0) generates a call to HAL_OSPI_DLYB_SetConfig in octospi.c even though I have configured the OctoSPI to bypass the delay block.
  1. Is it safe to just remove any Delay Block related code?
  2. Is this a bug in CubeMX? It increases the code size, so I would like it to be removed if it's not necessary
My target is a Nucleo-U5A5.
Thanks!
Timon Zijnge
KDJEM.1
KDJEM.1Best answer
Hello @tzijnge,
Thank you for bringing this issue to our attention.
I reported it internally.
• Bypassed if DLYBYP = 1 (no phase shift effect on DQS signal strobe). You can remove the delay Block related code.
• Used if DLYBYP = 0 to phase-shift DQS if unit delays are enabled and configured.
Internal ticket number: 205608 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @tzijnge,
Thank you.
Kaouthar
KDJEM.1
Hello @tzijnge ;
The STM32CubeMX issue is resolved in STM32CubeMX version 6.15.0.
Thank you.
Kaouthar
