KAgga.1
Jun 8, 2022 11:31 AM UTC
NVIC_SetVectorTable() API not available in HAL
Hello There,
I'm working on IAP app and need to relocate vector table and came across NVIC_SetVectorTable().
But I'm not able to find this API. I'm using CubeIDE and did generate the initial code with inbuilt cube mx.
Any help is appreciated.
Regards,
Keshav Aggarwal
gbm
Jun 8, 2022 11:46 AM UTC
It's called NVIC_SetVector and it's defined in CMSIS core.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
KAgga.1
KAgga.1Author
Jun 10, 2022 11:34 AM UTC
Thanks for replying.
I got the alternate, used VECT_TAB_OFFSET in system_stm32f4xx.c
Jun 10, 2022 11:44 AM UTC
Could also use the symbol for the table address, and let the linker fix that based on the linker script established base address for the image.
KAgga.1
KAgga.1Author
Jun 17, 2022 12:44 PM UTC
Thanks for replying,
There is a change. I'm using dual bank configuration and active bank will be different after each update.
So, need to change vector table address dynamically. I'm thinking to changing it from main(). or what do you suggest?
