JLemi
Jan 9, 2022 5:36 PM UTC
Null pointer exception in Eclipse when opening IOC file
When running /opt/st/stm32cubeide_1.8.0/stm32cubeide under Ubuntu 20.04.3 LTS, I get the following NPE when double-clicking on the ioc file. Nothing happens at the UI level. I include the ioc file that makes the program crash in case it could be useful. Thank you.
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
   at com.st.microxplorer.plugins.projectmanager.model.ProjectSettings.setM_mainLocation(ProjectSettings.java:457)
   at com.st.stm32cube.common.mx.editor.CubeMxEditor.getMxTabbedPaneInstance(CubeMxEditor.java:1111)
   at com.st.stm32cube.common.mx.editor.CubeMxEditor$11$1.createSwingComponent(CubeMxEditor.java:1025)
   at com.st.stm32cube.common.mx.oss.core.awtswtbridge.EmbeddedSwingComposite.doComponentCreation(EmbeddedSwingComposite.java:492)
   at com.st.stm32cube.common.mx.oss.core.awtswtbridge.EmbeddedSwingComposite$4.run(EmbeddedSwingComposite.java:291)
   at com.st.stm32cube.common.mx.oss.core.awtswtbridge.AwtEnvironment$2.run(AwtEnvironment.java:166)
   at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
   at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
   at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
   at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
   at java.base/java.security.AccessController.doPrivileged(Native Method)
   at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
   at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
   at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
   at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
   at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
   at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
   at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
   at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
