karsparskambala
NemaGFX folders are not generated when the app is created using STM32CubeMX
Hi all,
When I create a TouchGFX application starting from CubeMX, the following folder and its subfolders are not generated:
{ProjectName}\Appli\Middlewares\ST\touchgfx_components
GPU2D is enabled, and “Use GPU2D acceleration” is set to True under the X-CUBE-TOUCHGFX package settings.
However, when I create a TouchGFX project using TouchGFX Designer and select the STM32N6570-DK, these folders are generated correctly.
Am I missing a configuration step in CubeMX?
Thanks so much!
Hello ​@karsparskambala
Let me thank you for posting.
For more investigation, I recommend that you provide your Ioc.File.
Thanks.
Mahmoud
