mchin.1
Nov 24, 2021 8:47 AM UTC
my STM32F469I-DISCO kit internal RTC is not running . what is the isuue?
Hi , I am working on STM32F469I-DISCO kit.
In that actually Internal RTC time is not running
I configured internal rtc from cubemx. I am getting Time what i did set time only.
no more time is running. support me what the issue for not running time.
Nov 24, 2021 9:47 AM UTC
Please edit and refine question so the entire question isn't​ in the Summary..
F​or the RTC to keep running it needs to be using the LSE clock, and you need to go into low power modes, and make a special effort not to reset or clear the RTC when restarted or reset.
mchin.1
mchin.1Author
Nov 24, 2021 9:58 AM UTC
ok I changed .
I already used the LSE clock in clock configuration. It shows 32.768Khz to RTC clcok.
you mentioned low power modes. how can i select low power mode.
mchin.1
mchin.1Author
Nov 24, 2021 5:53 PM UTC
hi please give me solution for rtc time keep running for STM32F469I_Disco kit
Nov 24, 2021 8:57 PM UTC
I suspect you'll need to go beyond CubeMX, and perhaps fish in the CubeF4 example library for the DISCO/EVAL boards to find some good RTC / PWR examples.
Most of my F4 work was done with the SPL, and forum content about that has been lost/destroyed.
Briefly,
STANDBY is the lowest power mode.
You need to determine the cause of Reset, ie exit from standby, wake-up, etc.
You need to determine if the RTC/LSE is running already, and not break or reset it, thereby losing the time information.
The examples are not complete/available for all boards, some analysis and porting tends to be involved.
STM32Cube_FW_F4_V1.25.0\Projects\STM32469I_EVAL\Examples\PWR\PWR_STANDBY\Src\main.c
waclawek.jan
Nov 24, 2021 11:17 PM UTC
Read out and check/post content of RCC_BDCR and all RCC registers.
