MX project - Code can't be generated when there is '&' sign in the name
I used CubeMX 5.6.1 and then I tried to generate code for project with '&' sign in it, and generation stucked in Copying library files. I restarted CubeMX several times, but nothing changed so I deleted '&' sign and everything goes fine. I tried again by adding '&' and generation of code stuck. Is this some kind of bug in the CubeMX? I'm using Windows 10.
Thanks in advance,
Nenad
