hpark.21
Dec 21, 2022 6:12 AM UTC
Multiple adc conversions using DMA (help please)
1.volatile uint16_t ADC_Value[4];
-this is my array for the values to be stored
2.void ADC1_Configure(void)
  ADC_InitTypeDef ADC_InitStructure;
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 4;
  ADC_Init(ADC1, &ADC_InitStructure);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 2, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 3, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 4, ADC_SampleTime_55Cycles5);
  //ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
  ADC_DMACmd(ADC1, ENABLE);
  ADC_Cmd(ADC1, ENABLE);
  ADC_ResetCalibration(ADC1);
  while(ADC_GetResetCalibrationStatus(ADC1));
  ADC_StartCalibration(ADC1);
  while(ADC_GetCalibrationStatus(ADC1));
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
-and here i want to get 4 inputs of adc, so i made 4 config lines for the 4 adc channels
3.void DMA_Configure(void)
  DMA_InitTypeDef DMA_InitStructure;
  DMA_DeInit(DMA1_Channel1);
  DMA_StructInit(&DMA_InitStructure);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_Value;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 2;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Enable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  DMA_Cmd(DMA1_Channel1, ENABLE);
-and this is my dma configuration code
when i show my results of the array on the lcd the lcd keeps giving weird results for ADC_Value[0] and ADC_Value[1] but 0 for ADC_Value[2] and ADC_Value[3] ....
what could be possibly wrong?
Javier1
Principal
Dec 21, 2022 10:20 AM UTC
Is DMA initialiced before the ADC? it should be
It is a known CUBEMX issue.
Also check the buffer sizes you configured, they might not match with your real buffer.
hit me up in https://www.linkedin.com/in/javiermuñoz/
Piranha
Principal III
Dec 22, 2022 2:10 AM UTC
All of these are wrong.
