Minor bug in stm32f4xx_hal_dcmi.c, HAL_DCMI_MspInit gets called twice.
In HAL_DCMI_Init() of stm32f4xx_hal_dcmi.c, HAL_DCMI_MspInit() gets called twice.  The 2nd call should be deleted from the source.  See lines 216 and 218.
STTwo-32
STTwo-32Best answer
Hello @jmackey
Thanks again for reporting this behavior. I've escalated this to the concerned team for update on the future (under internal ticket number 213452).
Best Regards.
STTwo-32
STTwo-32
Hello @jmackey and welcome to the ST Community.
Thank you for reporting this behavior. Could you please attach your .ioc file here.
Best Regards.
STTwo-32
jmackeyAuthor
.ioc file attached as requested.
I also attached the file noted in the original message.
Regards,
Jon
STTwo-32
STTwo-32Best answer
Hello @jmackey
Best Regards.
STTwo-32
