parth kothiya
Dec 12, 2021 3:44 PM UTC
Migrating project to new cubeMX is giving lots of errors.
migrating old cubemx project in to new version of cubemx will give me errors while i compile it using STM32 CUBE IDE.
old project compiled successfully no errors.
Dec 12, 2021 4:15 PM UTC
Look at the errors and fix them. Start with the first one as errors can propagate.
S.Ma
Principal
Dec 13, 2021 5:04 AM UTC
Evaluate if rebuild the project from scratch and adding your source files is faster than error fight. It is a good skill to grow especially when migrating from other toolchains or other non ST vendors projects anyway.
Khouloud OTHMAN
Dec 15, 2021 4:23 PM UTC
Hello @parth kothiya​ ,
First let me thank you for your feedback.
Normally errors should not appear after migration from an old STM32CubeMX version to a new one.
Could you please share your .ioc file for further check.
Thanks in advance.
Khouloud.
parth kothiya
Dec 22, 2021 8:57 AM UTC
Error is gone if I delete other files excluding main.c then regenerate code then rebuild ​
