M.umit
Jun 11, 2020 12:00 PM UTC
makefile:43 error pls help
Hi!
I am trying to create a very first Hello World project like that:
 * @file      : main.c
 * @author     : Auto-generated by STM32CubeIDE
 * @brief     : Main program body
 * @attention
 * <h2><center>&copy; Copyright (c) 2019 STMicroelectronics.
 * All rights reserved.</center></h2>
 * This software component is licensed by ST under BSD 3-Clause license,
 * the "License"; You may not use this file except in compliance with the
 * License. You may obtain a copy of the License at:
 *            opensource.org/licenses/BSD-3-Clause
#if !defined(__SOFT_FP__) && defined(__ARM_FP)
 #warning "FPU is not initialized, but the project is compiling for an FPU. Please initialize the FPU before use."
#endif
#include<stdio.h>
int main(void)
printf("Hello World\n");
for(;;);
But I have encountered an error like that:
14:35:10 **** Incremental Build of configuration Debug for project 001HelloWorld ****
make -j4 all
arm-none-eabi-gcc "../Src/syscalls.c" -mcpu=cortex-m4 -std=gnu11 -g3 -DSTM32 -DSTM32F407G_DISC1 -DSTM32F4 -DSTM32F407VGTx -DDEBUG -c -I../Inc -O0 -ffunction-sections -fdata-sections -Wall -fstack-usage -MMD -MP -MF"Src/syscalls.d" -MT"Src/syscalls.o" --specs=nano.specs -mfloat-abi=soft -mthumb -o "Src/syscalls.o"
arm-none-eabi-gcc -o "001HelloWorld.elf" @"objects.list"  -mcpu=cortex-m4 -T"C:\Users\MehmetUmit2\MCU_STM32\MCU1_Project\First\001HelloWorld\STM32F407VGTX_FLASH.ld" --specs=nosys.specs -Wl,-Map="001HelloWorld.map" -Wl,--gc-sections -static --specs=nano.specs -mfloat-abi=soft -mthumb -Wl,--start-group -lc -lm -Wl,--end-group
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: error: Src/sysmem.o uses VFP register arguments, 001HelloWorld.elf does not
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: failed to merge target specific data of file Src/sysmem.o
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:43: 001HelloWorld.elf] Error 1
"make -j4 all" terminated with exit code 2. Build might be incomplete.
14:35:11 Build Failed. 1 errors, 0 warnings. (took 1s.273ms)
How can I solve it. Thanks for all the help!
Jun 11, 2020 12:04 PM UTC
The error is saying half of your project uses the FPU, and half does not. Change "-mfloat-abi=soft" to "-mfloat-abi=hard -mfpu=fpv4-sp-d16".
M.umit
M.umitAuthor
Jun 11, 2020 12:33 PM UTC
I have changed them. But there is still an error:
15:21:51 **** Incremental Build of configuration Debug for project 001HelloWorld ****
make -j4 all
arm-none-eabi-gcc -o "001HelloWorld.elf" @"objects.list"  -mcpu=cortex-m4 -T"C:\Users\MehmetUmit2\MCU_STM32\MCU1_Project\First\001HelloWorld\STM32F407VGTX_FLASH.ld" --specs=nosys.specs -Wl,-Map="001HelloWorld.map" -Wl,--gc-sections -static --specs=nano.specs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb -Wl,--start-group -lc -lm -Wl,--end-group
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: error: 001HelloWorld.elf uses VFP register arguments, Src/main.o does not
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: failed to merge target specific data of file Src/main.o
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: error: 001HelloWorld.elf uses VFP register arguments, Src/syscalls.o does not
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: failed to merge target specific data of file Src/syscalls.o
15:21:52 Build Failed. 1 errors, 0 warnings. (took 938ms)
Jun 11, 2020 12:41 PM UTC
How did you generate your code? Create a project in CubeMX and start with that. Where is src/syscalls.c coming from?
