bonumaster
Aug 7, 2018 10:33 AM UTC
LWIP not getting generated in CubeMX new release Version 4.26.1
Currently, I am working on STMH43ZITx Nucleo board. In order to generate code for Ethernet as well as LWIP, I am using STMCubeMX. After updating STMCubeMX to the newest version i.e 4.26.1, I cant able to select LWIP option at all even after selecting ETH option to RMII/MII.
The same works if I select other boards for example STM32F7 series.
Is that bug in the newest release of STM32CubeMX or I am doing something wrong?
Best regards,
Sid
Imen.DBest answer
Aug 7, 2018 11:12 AM UTC
You should first enable the ETH IP and FREERTOS with MBEDTLS, to active LWIP for STM32H7
Also, CORTEX_M7 CPU DCache parameter must be enabled.
This warning is mentioned when you put the cursor in LWIP Pinout.
Hope this helps you.
With Regards,
Imen
Imen.DBest answer
With Regards,
Imen
bonumaster
Aug 7, 2018 12:02 PM UTC
Hi Imen DAHMEN,
Thanks alot!!
