LPBAM data build indentation inconsistensies
STM32CubeMX generates inconsistent indentation in MX_Recieve_Q_Build:
* @brief CLIP application Data scenario Receive queue build
* @param None
* @retval None
static void MX_Receive_Q_Build(void)
/* LPBAM build variable */
LPBAM_DMAListInfo_t pDMAListInfo_LPGPIO = {0};
LPBAM_GPIO_PinSeqFullAdvConf_t pReadPinSeqFull_LPGPIO = {0};
LPBAM_COMMON_TrigAdvConf_t pTrigConfig_LPGPIO = {0};
LPBAM_COMMON_DataAdvConf_t pDataConfig_LPGPIO = {0};
* Receive queue CLPReceiveBits build
pDMAListInfo_LPGPIO.QueueType= LPBAM_LINEAR_ADDRESSING_Q;
pDMAListInfo_LPGPIO.pInstance= LPDMA1;
pReadPinSeqFull_LPGPIO.Pin = LPBAM_GPIO_PIN_0;
pReadPinSeqFull_LPGPIO.Size = 13;
pReadPinSeqFull_LPGPIO.pData = (uint32_t*)&receivedBits[0];
if (ADV_LPBAM_GPIO_ReadPinSequence_SetFullQ (LPGPIO1, &pDMAListInfo_LPGPIO, &pReadPinSeqFull_LPGPIO, &Receive_Q_CLPReceiveBits_Desc, &Receive_Q) != LPBAM_OK)
Error_Handler();
pTrigConfig_LPGPIO.TriggerConfig.TriggerMode = LPBAM_DMA_TRIGM_SINGLE_BURST_TRANSFER;
pTrigConfig_LPGPIO.TriggerConfig.TriggerPolarity = LPBAM_DMA_TRIG_POLARITY_RISING;
pTrigConfig_LPGPIO.TriggerConfig.TriggerSelection = LPBAM_LPDMA1_TRIGGER_LPTIM3_CH1;
if (ADV_LPBAM_Q_SetTriggerConfig (&pTrigConfig_LPGPIO, LPBAM_GPIO_READPINSEQ_FULLQ_DATA_NODE, &Receive_Q_CLPReceiveBits_Desc) != LPBAM_OK)
Error_Handler();
pDataConfig_LPGPIO.TransferConfig.Transfer.SrcInc = LPBAM_DMA_SINC_FIXED;
pDataConfig_LPGPIO.TransferConfig.Transfer.DestInc = LPBAM_DMA_DINC_INCREMENTED;
pDataConfig_LPGPIO.TransferConfig.Transfer.SrcDataWidth = LPBAM_DMA_SRC_DATAWIDTH_HALFWORD;
pDataConfig_LPGPIO.TransferConfig.Transfer.DestDataWidth = LPBAM_DMA_DEST_DATAWIDTH_BYTE;
pDataConfig_LPGPIO.TransferConfig.Transfer.TransferEventMode = LPBAM_DMA_TCEM_LAST_LL_ITEM_TRANSFER;
pDataConfig_LPGPIO.UpdateSrcInc = DISABLE;
pDataConfig_LPGPIO.UpdateDestInc = DISABLE;
pDataConfig_LPGPIO.UpdateSrcDataWidth = DISABLE;
pDataConfig_LPGPIO.UpdateDestDataWidth = ENABLE;
pDataConfig_LPGPIO.UpdateTransferEventMode = DISABLE;
if (ADV_LPBAM_Q_SetDataConfig (&pDataConfig_LPGPIO, LPBAM_GPIO_READPINSEQ_FULLQ_DATA_NODE, &Receive_Q_CLPReceiveBits_Desc) != LPBAM_OK)
Error_Handler();
Hello ​@SamMiddleton
Let me thank you for bringing this issue to our attention.
The issue has been reported to the dedicated team (Internal Ticket number: CDM0064121).
I will keep you up to date until the problem is fixed.
Thanks.
Mahmoud
Let me thank you for posting.
I am currently checking this behavior, and I will get back to you ASAP.
Thanks.
Mahmoud
Thanks.
Mahmoud
