SSing.10
Oct 27, 2021 9:04 AM UTC
Issues with new Firmware Packages for STM32L4R5ZI Nucleo board
Hi All,
I am working on my Nucleo-L4R5ZI board and facing issues with firmware sdk packages downloaded by "Stm32cubeMx" and "Stm32CubeIDE" software respectively.
I am just trying to test the board using simple led toggle program but it unable to make it toggle properly and tested in other different IDE but issues remain same & present.
Then I have tested it some older developed program using keil IDE it works in that environment, means in older firmware packages it works but not in new latest ones.
(Note - My older firmware packages was deleted and after setting up new Stm32CubeMx it downloads new latest which is not working with my board)
I request you all to please share the possible solution for the same.
I am sharing my very simple and basic IOC file to re-create & perform the same for testing.
Thanks & Regards
SS
SSing.10
SSing.10Author
Nov 4, 2021 12:48 PM UTC
Hi
I started to test the same code in the EWARM IDE as mentioned, but after connnecting the board to the system/pc is gives error msg in the text format while - "The interface firmware FAILED to reset/halt the target MCU".
Also I observed that PWR Led is flashing after connecting with the system/pc to test it.
I observed the each and every component mounted on the board to verify the any broken/short/burnt/damages but looks ok oin board with visual inspection.
I request you please let me know the further steps & thing to make up the board running.
SS
