AScha.3Best answer
>it insist the frequency will be 255MHz but shouldn't it be 250MHz
Maybe - its right ? Because you set the fractional divider ....set it to zero, then try again.
btw
You set 4096 , so it gives F= Fref x (divn + 0,5 ); with Fref 10MHz, you get 5 MHz "added" .
