Is there a fix on using FREERTOS + FATFS + SDIO + DMA?
I am creating a project for the STM32F767ZI. The Fatfs library WITHOUT freeRTOS works well. When I include freeRTOS in my project, I cannot get past mounting the disk:
retSD = f_mount(&SDFatFS, (TCHAR const*) SDPath, 1);From reading the forums, I found that some people have found a solution for certain MCUs. Is there a configuration where I can use FREERTOS + FATFS + SDIO + DMA?
My cubemx settings are as follows: I am using SDIO 1 bit bus and DMA for RX and TX. I have set my stack size to 0x2000, my heap size to 0x4000. I'm using FatFS with the DMA template.
