MaxC
Into CubeIde or CubeMX is there a way to generate a Report (for documentation) for all the MCU configuration ?
  • March 1, 2023
  • 2736 views
Best answer by Sarra.S
Hello @MaxC​,
Yes, you can use the CubeMX Report Generator Tool
In STM32CubeMX, select File > Generate report, the output is a pdf file that contains the project configuration report
Hope that helps!
Sarra.SBest answer
Hello @MaxC​,
Hope that helps!
MaxC
MaxCAuthor
Thank you for the feedback.
