RGarc.1
February 19, 2020
Install X-CUBE-SUBG1 in STM32CUBEMX
Hello!
I want to make a basic remote control with the SPSGRF-915 module, but as far as I can understand I need the X-CUBE-SUBG1 extensión software to control it.
I have already downloaded the software from ST (en.x-cube-subg1_firmware) and on the STMicroelectronics tab from the Embedded Software Package Manager in CubeMX, I can´t find the extensión package, so I tried to upload from the local .zip previusly downloaded but the following error appears:
The following file is not recognized as being valid ...
Thanks for your attention
Laurent Co
Laurent CoBest answer
Hello JRuiz,
Unfortunately, The X-CUBE-SUBG1 is not enhanced for STM32 toolset.
You could find the ones enhanced with the link below, looking at the corresponding column:
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages.html#products
Regards,
Laurent
JRuiz.1
June 29, 2022
Hi!
I'm trying to do the same and getting the same errors.
Did you get and answer or a solution?
Laurent Co
Hello JRuiz,
Regards,
Laurent
