Andrew Neil
Inconsistent pin naming
I've always found it a little irritating:
#define CLK_A_Pin GPIO_PIN_0
#define CLK_A_GPIO_Port GPIOF
Why is it deemed necessary to have "GPIO" in one, but not the other?
Surely, that should be either:
#define CLK_A_GPIO_Pin GPIO_PIN_0
("GPIO" in both),
Or:
#define CLK_A_Port GPIOF
 ("GPIO" in neither)
(There isn't a label for "suggestion" - so "bug report" is the nearest option)
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @Andrew Neil
Your change request ID is  #0060783
I will keep you posted with updates.
@Andrew Neil wrote:
I haven't had a chance to try CubeMX2 yet - does the same apply there?
Any question related to MX2 should be posted in the MX2 forum, where you can receive complete technical support from the dedicated team.
STM32CubeMX2 (MCUs) - STMicroelectronics Community
THX
Ghofrane
Ghofrane GSOURI
Hello @Andrew Neil
I believe your request is valid and reasonable.
It will improve clarity and consistency, especially in larger projects, and will also help with code readability and maintainability.
I am raising this change request with our development team.
THX
Ghofrane
Andrew Neil
Thanks.
Ghofrane GSOURI
Hello @Andrew Neil
THX
Ghofrane
mƎALLEm
I do agree with @Andrew Neil , meanwhile that may break completion of previously generated code of user projects.
unsigned_char_array
Lead III
I agree. It should be an option for the user to select a different pin naming. The default should be backwards compatible.
Personally I think pin and port both need to be uppercase. It's convention to have #define constants all upper case.
So I would prefer if it was something like this:
#define CLK_A_GPIO_PIN GPIO_PIN_0
#define CLK_A_GPIO_PORT GPIOF
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
Andrew Neil
Agreed.
But this would affect all #define symbols generated by CubeMX - not just pin/port names.
Maybe start a separate thread for that ... ?
Andrew Neil
@mƎALLEm @unsigned_char_array  Yes, there would be an issue if an old project were opened in a newer CubeMX which made this change.
That should, at the very least, give a warning.
Preferably an option to change or not.
@Ghofrane GSOURI I forgot to say that my preference would be for both names to not have the "GPIO"; ie,
I'm all for brevity; the "GPIO" seems entirely redundant.
