ATvit
Jun 10, 2019 4:51 AM UTC
i generate code using cube. i use freertos andtimer interrupt. the timer interrupt is not work i dont know whay. i open example project and copy my timer hardware configuration to the project and is work ok. advice thanks
Jun 10, 2019 6:50 AM UTC
Perhaps look critically at the interrupt loading and task switching you are causing.​
