Juras-RPM-Tech
Oct 29, 2018 8:13 PM UTC
I can not use QubeMX to set in the MX_ADC1_Init(void){} function call the following: hadc1.Init.ContinuousConvMode = is always set to DISABLE,
I want this:
hadc1.Init.ContinuousConvMode = ENABLE;
but I get this from QubeMX:
hadc1.Init.ContinuousConvMode = DISABLE;
Khouloud ZEMMELI
Nov 26, 2020 2:22 PM UTC
Hello @Juras-RPM-Tech​ ,
Could you please check with the latest CubeMX version ?
If issue still appears please share you ioc file to check it.
Best Regards,
Khouloud
