AJadh.1777
Nov 28, 2019 12:29 PM UTC
I am using a microcontroller STM32F103C8T6. The code has been generated from STM32 CubeMx and exported to keil. I have enabled both the UARTs. While transmitting the frames, I could observe only 0x00 getting transmitted in both the ports.
No assembly code is generated for UART initialize call function.
Pavel A.
Nov 28, 2019 4:13 PM UTC
Really? Cube has generated C code, but it won't translate to any "assembly"?
--pa
AJadh.1777
Nov 29, 2019 2:43 PM UTC
Yes. Its real.
Pavel A.
Nov 29, 2019 2:57 PM UTC
Is this C code in the generated stm32....hal_msp.c file? And in Keil, do you use the ARMCC compiler (v5) or gcc-like compiler (v6)?
