GGuer.1
I am new of the bluetooth argument. My application is based on STM32F411. I need to communicate with an external HCI bluetooth board via UART, but I do not find the correct stack for doing that.
I try to configure my project by Cube MX enabling additional software X-CUBE-BLE2 as start point. When I try to compile I get the error "hci.h not found". I think something is missing, but all the code is Cube generated,
Is there a ready to use HCI stack for my purpose? Where can I find it?
Khouloud ZEMMELI
​Hello @GGuer.1​ ,
All CubeMX examples are under C:\Users\...\STM32Cube\Repository\ .
Otherwise, could you please share your ioc file to check the problem?
Thanks,
Khouloud
GGuer.1
GGuer.1Author
You can find my ioc in the attachment.
Thanks.
Khouloud ZEMMELI
​You're right @GGuer.1​ , the point you raised will be internally  treated ,I will give you an update as soon as possible.
Thanks for your feedback,
Best Regards,
Khouloud
Khouloud ZEMMELI
​Hi @GGuer.1​
When the CMSIS Pack is  green, all config is OK, otherwise, there's somting missed
In your case the Wireless BlueNGR-2 should be also checked.
Best Regards,
Khouloud
GGuer.1
GGuer.1Author
The compilation is ok now.
Thanks!
