FBahr
May 16, 2019 2:18 AM UTC
I am having problem with RTC interrupt of STM32F103. I want my program to go to RTC interrupt every second but it does not work. HAL_RTC_IRQHandler () function never call. Thanks
turboscrew
Senior III
May 16, 2019 5:52 AM UTC
Are you using CubeMX?
Have you enabled the interrupt in NVIC and RTC?
tarasov.alex.m
May 16, 2019 9:03 AM UTC
It's hard to tell the problem without seeing your code, that initializes the RTC. As it was mentioned above, probably you havn't enabled the interrupt or configured it in a wrong way.
