RShar.9
Jan 4, 2020 8:44 AM UTC
How to use DAC channal output as ADC REF voltage intenally
Hello
i am working on stm32h7 and i want to use  DAC channal output as ADC REF voltage intenally.
can any please tell how to do it
berendi
Principal
Jan 4, 2020 2:09 PM UTC
The DAC needs the reference voltage to function, so it cannot generate it.
RShar.9
RShar.9Author
Jan 4, 2020 3:21 PM UTC
thanks for reply
if i connect dac channal output to adc ref+ what will happen is that any problem.
RShar.9
RShar.9Author
Jan 4, 2020 3:25 PM UTC
in that situation dac output will also vary because dac reference also vary????
oeliks
Jan 5, 2020 8:12 AM UTC
Try to : Read vref - set dac low value - read dac output with the same adc but different channel - compare with vref - increase dac value untill it matches vref?
connect output of dac to input of adc
Dvorak.Peter
Jan 5, 2020 1:13 PM UTC
It can be done externally with an op-amp.
But I see no real benefit to this
