MKash.1
May 23, 2023 8:22 AM UTC
How to set FDCAN baud rate 8 MBit/s in CubeMX?
MKash.1
MKash.1Author
May 24, 2023 7:06 AM UTC
So, why last working BR=2500KB/s?
LCE
Principal III
May 24, 2023 7:31 AM UTC
What do you exactly mean?
You have set nominal bitrate to 2.5M and it is "working"?
Working with what on the other side? Or just some output on the scope?
MKash.1
MKash.1Author
May 24, 2023 3:44 PM UTC
Yes, I have 2 boards (MASTER-SLAVE) and they work perfectly on BR=2.5M
LCE
Principal III
May 24, 2023 7:30 AM UTC
Have you enabled transceiver delay compensation?
May 24, 2023 3:51 PM UTC
*THIS*
We covered this a few months ago, don't recall if it was for the U5, probably H7, but definitely found and provided 8 Mbit FDCAN initialization example.
Sort of s**t the code generator or boiler plate code should have mastery of...
LCE
Principal III
May 25, 2023 8:00 AM UTC
TDC was definitely a problem I had on a H7 at 8Mbit, and I had a long thread about it.
I'm actually using direct register settings, and I even enabled TDC. But what I oversaw was that I also had to set a delay value in TDCR...
@MK.1ashin​  HAL_FDCAN_ConfigTxDelayCompensation() handles all of that.
