MQ_it
Oct 4, 2019 11:49 AM UTC
How to install Firmware Package ?
There would be a training course for STM32G4 in our city on Oct.22, I was accepted and was asked to install 3 software:
1.STM32CubeMX V5.2.1
2.STM32CubeG4 Firmware Package
3.IAR EWARM V8.40.1
I have installed the first one, while the second is more than 680 MB, when I want to extract it, my computer just stopped there, I tried several times, all the same. My computer is HP Z-workstation, so how could I install these packages ? Then training notification said, one could install the package in STM32CubeMX V5.2.1, but I could not find the entry. Any suggestion ?
Oct 4, 2019 12:30 PM UTC
Perhaps work with your IT dept?
Check for things like AV blocking the install, or firewall/proxy settings blocking downloads. Version of Java/JRE installed.
The CubeG4 package can be downloaded from here https://www.st.com/en/embedded-software/stm32cubeg4.html
And then installed manually (From Local) into CubeMX
MQ_it
MQ_itAuthor
Oct 5, 2019 2:16 AM UTC
Thanks, your link works.
MQ_it
MQ_itAuthor
Oct 7, 2019 2:44 AM UTC
Thank you again, your file inspired me. When I downloaded and began to extract it, it responded same with before, while I was confused and didn't know what to do, it was starting, so this inspired maybe I waited not long enough before, when I restarted my file, I waited and waited, then it was start to extract.
My file is near 1.9 G, so waiting for longer time is reasonable.
