ZdenekK
Feb 21, 2023 10:06 PM UTC
How to define LwIP DHCP hostname in CubeMX?
I am wondering how to set the DHCP hostname for LwIP when using STMCubeMX. The CubeMX tool creates a definition for the hostname in ethernetif.c:
 #if LWIP_NETIF_HOSTNAME
 /* Initialize interface hostname */
 netif->hostname = "lwip";
#endif /* LWIP_NETIF_HOSTNAME */
However, this is "hard wired" in CubeMX. If I change it manually in ethernetif.c, CubeMX rewrites it to the default value "lwip" after each change in the IOC definition. There is no option in CubeMX for the DHCP hostname.
I am using the latest FW, latest Cube tools (CubeIDE version 1.11.0, CubeMX version 6.7.0).
BTW, I found the same question in the forum, four years old
( but with no satisfactory answer.
Thanks in advance for help
Best Regards
Zdenek
MSG_ST
MSG_STBest answer
Mar 7, 2023 9:51 AM UTC
Thank you for raising this point.
A fix will be done to make "netif->hostname" configurable via CubeMX.
Internal ticket number: 147052
(This is an internal tracking number and is not accessible or usable by customers).
Thank you for your contribution.
Mahdy
MSG_ST
MSG_STBest answer
Mahdy
ZdenekK
ZdenekKAuthor
Mar 7, 2023 2:03 PM UTC
Hi Mahdy,
many thanks for taking care.
Best Regards
Zdenek
Amel NASRI
Nov 30, 2023 9:01 AM UTC
Issue already fixed since STM32CubeMX 6.9.0.
Feb 16, 2024 5:02 PM UTC
Has this fix ever been done ? I cannot see an option on CUBEIDE in the LWIP section to set the Hostname
