hmc
Jul 4, 2016 7:55 PM UTC
How to change the output dir for existing CubeMx project?
Posted on July 04, 2016 at 21:55
Hello, is there any way to change the output dir (I guess it's the same as Toolchain Folder Location?) in CubeMX?
#cubemx-output-folder
Nesrine M_O
Jul 5, 2016 1:53 PM UTC
Posted on July 05, 2016 at 15:53
Hi choi.henry,
I will forward your request to our MX team.
-Syrine-
stm32cube-t
Jul 19, 2016 8:48 AM UTC
Posted on July 19, 2016 at 10:48
The project folder can not be changed. The workaround is to save the existing project as a new project: select the menu ''File > Save Project as'' and specify there a new project name (optional) and new destination folder.
Note this will create the project folder and save in there the project .ioc file only.
You will have to click ''generate code'' to retrieve the generated initialization code at the new location.
Best regards
