Steven Keeter
Feb 3, 2020 6:06 PM UTC
How to best configure and utilize CubeMX when using additional third-party drivers like embOS from Segger?
Hello, I am using CubeMX to configure the STM32H745II-Discovery device and am also using several drivers from Segger. Like embOS , and others for example. Because CubeMX does not readily support Segger drivers, how best can I utilize CubeMX with these third party drivers and not have to do so much manual project manipulation each time I need to change a pin or periheral using CubeMX? I see some project management options but haven't figured out the best combination.
