LOnGr.1
How to add USB HAL driver to a register based project
Hi!
My question may seem stupid but I am stuck with it. I made a register based project which is working pretty good. I want to add to my project usb cdc. I generated a code using CubeMX but it generates plenty of drivers and files (including the clock that I already configured using registers). Can someone give me an idea on how to integrate these HAL files (I understood that USB is only HAL, if there's any other way please tell me) into my register based project. Or maybe there is a way to not use CubeMX at all and do it manually?
Thank you!
