KNish.2
Aug 5, 2020 11:14 AM UTC
How do I integrate X-CUBE-CLASSB Safety Library into my project?
Hello all,
I downloaded the X-CUBE-CLASSB library from the ST website and I'm stuck trying to integrate it into a project. The same issue has been discussed in 2017 in this thread with no solution: https://community.st.com/s/question/0D50X00009XkXsFSAV
Unfortunately, I already had to learn that this library can not be used with the CubeMX code generation tool and has to be integratedmanually.
Does someone have a solution? The documentation is no help and only explains all library functions.
Thank you in advance!
